Posted (edited)
PROBLEM SOLVED.
Edited by Spitfire2k6
Live life to the full... Then TURN THAT BITCH UP!
Posted (edited)
it sounds like you own a modem. you need a router depending on what you want to spend either the mac airport or netgear are the two I would use. I have owned a few different types and those are the easiest to set up. Does your school not have wifi on campus? In theory a wireless router should think of the ethernet port from the wall as a modem so it should do the job and allow multiple computers to access the one source.
Edited by photochrisb931
Barstad
Sounds like you have modems not routers.
For what you want to do is simple. Go to best buy and get a cheap linksys wireless router. It's basically plug and play unless your hooking up a game system where you would just need to port forward that device, if that line let's you.
You can connect the ethernet wire to your PC, if it has wireless capbabilities itself, get a program called Connectify, it allows a computer to broadcast and pickup a special connection made by the program, which from their you can have the other devices pick it up.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I love how he states that he definitely has routers and everyone stll says he doesn't. Fail for OP! :clapping:
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
I love how he has 4 years of degrees in computing but cant figure out how to work a simple internet connection
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
They are routers... i know the difference dude...
And just because i have 4 years of degrees in computing does not mean i can set up a router on a network that is set up not to allow them.
Either way for both of you I'll just ignore that you were trying to belittle me which is against the rules of this forum and let you know i have since got the ROUTER connected... Fucking assholes...
why not get a ethernet hub and just wire everything lol just my input
He said he needed wireless connections as well.
I would recommend you get a wireless router, which you can set up based upon your university's connection settings. I have a Linksys WRT54g with the DD-WRT firmware on it. DD-WRT allows you to easily modify connection settings to whatever network you're connecting to.
What the other posters may have been missing is that nowadays, routers sometimes also have built-in modems, hence why you have ADSL or DSL connections available. If you still need help, ask away or send me a PM.
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
