I use hoppes and my bore brush it always does the job.... Trick is NOT to let the powder set and just build up in the gun.....After a day of shooting clean it promptly will make it much easier
Team MaxRetribution
Si Vis Pacem Parabellum
I've cleaned it after every time at the range but I looked at the rifling extra close instead of the "peek and twist" and just noticed a little build up (really tiny at the valley of the of the rifling) I let it sit overnight and it's still there.
I'll try leaving a wet patch of CLP and see if that helps.
I'll try the simple green on the lower next time
i dont thinhk id use simple green on it. that shit eats paint off.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Use Kano Kroil for soaking stuff that has a lot of residual build up on it...It's also great for freeing up frozen parts. It's a penetrating oil.
Check it out!
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
Do a google search on it. So far i have not hurt anything. I mostly clean handguns with it. I have soaked the aluminum s&W 642 in it overnight with no issues. I have not used it on anything blued.
not doubting you it just scares me. Ive seen what that stuff is capable of.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
