Sundown tline...
brent379
as the box is designed for the driver i dont see there being a limit on how much power you can put into one. the only limit is the driver itself
one thing to note though is most of the really high power subs would not work too well in a tline anyway
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Do two. More cone area never hurts a t-line ;)
Wouldent the box also be a lot bigger for 2 8s in the tline?
Nah, can build for a single 8 (or as much as you can anyways) and have two in it. Not a perfect scenario but will work fine.
This is one of the dumbest things i have seen on here in a while. Do you even have a clue how a t-line works or how to properly design one? With your comments i am going to assume no so please, keep your keyboard away from this topic.
Maybe you should go back and give horn and t-line theory another look like myself and foreverbumpin are doing. Linking t-line cross-sectional area to non-active driver area is old-school. It works fine, but it limits you to only building one kind of t-line.
Hammerdown... 1%
So would you consider throwing 2 15 inch subs with a resonant freq of 35hz in a t-line tuned to 35 hz running off 1200 watts rms a bad idea? There is a guy on youtube running 2 type r 15's in t lines and they sound excellent. I have plenty of room to try one myself and have built one already for a 12. Very nice sounding on 800 rms. Just wondering the opinion of the massive cone area mostly.
try it see what happens. there is theory and practice. i suggest practice over theory every day
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Are those t-lines in a jeep? If its the guy i'm thinking of he later went to 3 t-lines with 3 type-r 15's and has a build-log on here.
Hammerdown... 1%
THIS!
Do you already have the 2 8"s? If you do, say screw it- build a proper T-Line, see what it sounds like and then try it Isobaric. That could mess up the whole thing- or.... :peepwall: maybe not.
If you don't like it, toss it and build another one! And take pictures. We likes pictures. :popcorn: :popcorn:
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Probly the same guy, different vehicle I guess. Never seen the jeep
Yeah same guy, thought it was a jeep... was wrong lol.
Hammerdown... 1%
I am not impressed when people believe they have a great setup by showing their sheet metal roof flexing. I am more into watching doors open by themselves or wipers falling off the arms. My cheap power acoustik subs with a cheap amp do the same thing this does...Though they are in a horn type box. Probably helps. I just hate that I have to adjust my mirrors all the time and my drinks vibrate out of the cup holders...Maybe I shouldn't have drinks while listening then ehh?
"hit harder" never use that vocab again
on low power the 1 sub tline will walk the two 8s all day everyday
however the two in a standard box will be able to take more power and inevitably get louder. your call
Truf!! Y'all should listen to Matt, guy has quite a bit of knowledge when it comes to this stuff ;)
I love my staffie :good:
So anti FACEBOOK it isn't even funny
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
