Is it blown?
Coolbeans
IIRC on my brothers f-350 we grounded on a seat bolt as well but there is a thick black paint (probably model dependent) on the metal that really needed to be ground off with a dremel tool
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Yeah just slapping a ground to a bolt will not work at all. Properly take the time and use a dremel tool or if your like me and use a angle grinder lol. I bet if you clean up that ground something will change.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
100 amp seems a little too much for 4ga wire, I'd get it down to 80 max, 60 would be best but 80 would be fine. The fuse serves two purposes, to blow when it is shorted out (touching the ground of your vehicle) or when you draw more current thsn the wire can handle safely. That's what all fuses are made for, short circuits and over powering.
Edit: what kind of fuse holder is it? Is it an anl, agu, midi, etc.? Also do you have a reducer on the inputs of the fuse holder? A loose connection can cause a ton of heat.
Edited by kickass audio
4awg is good to 125amps at 12ft or so.
Fuse is fine.
Plenty of bad info in here
Well im getting a voltae drop in my power line at the fuse, because i measured the voltage when my amp was in protect and got a low reading looked at my fuse(at which point i was moving it around physically) and my amp powered on and i was getting 12.whatever volts at the amp so i dont think its the ground, cause i tried the power with actual bare metal of the body and read the same. Im thinking its the fuse holder cause of the build up and everything, but its just weird cause it was working fine until i decided to mess with things before a competition then i hit a note while tuning lost power and its been downhill ever since. off and on
So it comes on and off if you wiggle the fuse holder?
so far...
I'd try all new power wire and fuse/fuse holder, that's just me
so far...
  • Who's Online   1 Member, 0 Anonymous, 1162 Guests (See full list)
