Ok well im about to install a dd z2hv and its rated at 7700 watts at one ohm.so if you divide 7700 by 14.4 you get around 535 amps.if i put 3 pf dc powers 270 amp sp alternators on it will it cover it?they do 180 at normal temperature so that will be 540 amps but like on a hot day they only do 160 which that way will be 480 is that a huge difference to be worried about?i know i will be covered while driving but all these numbers are at idle..
Amps
1-DD Z2HV
Power bass asa 400.4 & 600.2
Alternators
3-mike singer 350a
Wiring
6 runs 2/0 welding cable front to back
Speakers
3 sets of crossfire c5x6 components
2 crossfire xs 15's dual 2 ohms
Batteries
To be decided
As far as alternators go your gunna be alright, I think the only thing I would look at is your battery bank now. I'm no expert on batts so I'm not going to tell you what to get, but someone will
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
But also if it's for a daily setup your not going to be getting 7000 watts out of it hardly ever if you ever even do! You are going to have box rise and unless you go around listening to a sine wave all day long you'll probably never pull 7000 watts worth of amperage. And if you are going to compete and burp it, that electrical with a good battery bank should be very stout
so far...
^this. as for the batteries i'm no help after the second battery. but i can tell you the XS D3100 is probably the biggest baddest one out there. so i'd say a few of those (maybe 3 or 4?) should do you good. i'm no expert, but meade has like 6 or 8 in his ride and you are running a lot less power than him.
hopefully somebody will chime in with the right answer here soon.
More box builds
I'm with captain stupid.
id say you would be fine with just the alts and maybe another bat or 2 if your gonna be demoing for long periods of time. but if your just gonna go daily then you should be good.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
well it depends on what amp you run....
I would say 3-4 D3100s,
or two of these
http://www.batteryspec.com/cgi-bin/cart.cgi?action=link&product=84
