kam311 Posted October 16, 2011 Report Posted October 16, 2011 Yeah op, you don't have to have 6 subs to get loud, if your on a tight budget 6 subs isn't your best option by any means so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
Supercharged DCs Posted October 16, 2011 Report Posted October 16, 2011 Before you buy any subwoofers, do you have the proper airspace to fit 6 12s ported? Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
soundstream15 Posted October 16, 2011 Report Posted October 16, 2011 ya like kam said, u dont need 6 subs to get loud, and if u build a small box cuz u dont got enough room then u wont see the output u should, i would just get ither 2 dc lvl 3s r sundown sa 12s, im running a aq 1200d and i love it, way better then my kicker kx1200..its up to u tho man, i never had the onx1500 r the ap1500..i no the new hifonics brutus are pretty good, my friend had the brz1700.1 i wasnt all that impressed with it..do be honest my aq amp is louder, just do some research cuz u still got awhile. good luck
armykyle1 Posted October 16, 2011 Report Posted October 16, 2011 the new brz amps are tanks TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
pitbullninja Posted October 16, 2011 Report Posted October 16, 2011 Bassstalker...if you have six 100 RMS subs then that's only 600 watts. Number of speakers/subs do not dictate current draw. On a note, if you need it to be cheap, why six 12"s? To provide a suggestion, Pioneer Championships. edit: cheap amps. Um...knowing what woofers, voicecoil configurations, and power would be very important factors. i was figuring in that he would need 2 possibly 3 amps. and most stock electrical cant handle more than 1000 watts. My friends running 4400 watts on stock although he's got a hemi so the alt is prolly pre-upgraded I call bullshit on that one man, I have a cummins and it's a lot bigger than the hemi, still the same 140amp or so alt and my truck even has two stock batts and the big three and I have a decent amount of voltage drop on 2k when I go full tilt, enough to have to turn it down for sure But I'm not... I saw what I saw he has a magnum or something like that idk what the cars called but the amp is 4k no extra batts or Nything. He does have a large cap tho
Trey_Dog650 Posted October 16, 2011 Report Posted October 16, 2011 But I'm not... I saw what I saw he has a magnum or something like that idk what the cars called but the amp is 4k no extra batts or Nything. He does have a large cap tho Lol ok As for the Op i have the Mb Quart ONX1500.1 and i love it. Greta bang for your buck imo. Also how are you going to orientate the subs... what kind of truck is it? 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
kam311 Posted October 16, 2011 Report Posted October 16, 2011 Bassstalker...if you have six 100 RMS subs then that's only 600 watts. Number of speakers/subs do not dictate current draw. On a note, if you need it to be cheap, why six 12"s? To provide a suggestion, Pioneer Championships. edit: cheap amps. Um...knowing what woofers, voicecoil configurations, and power would be very important factors. i was figuring in that he would need 2 possibly 3 amps. and most stock electrical cant handle more than 1000 watts. My friends running 4400 watts on stock although he's got a hemi so the alt is prolly pre-upgraded I call bullshit on that one man, I have a cummins and it's a lot bigger than the hemi, still the same 140amp or so alt and my truck even has two stock batts and the big three and I have a decent amount of voltage drop on 2k when I go full tilt, enough to have to turn it down for sure But I'm not... I saw what I saw he has a magnum or something like that idk what the cars called but the amp is 4k no extra batts or Nything. He does have a large cap tho Just because an amp says 4000 watts on it does not mean that the amp makes 4000 watts, and even if it did actually do rated he could have it wired at 1ohm. But there is no way that you are getting 4000watts out of stock electrical, it's just not possible. You've been tricked bud so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
pitbullninja Posted October 16, 2011 Report Posted October 16, 2011 6 dual 12s 30$ ea @ walmart rms is like 300 ea don't go over that get a hifonics 1-1.2k watt amp or a sound stream thats something cheaper. thats the cheapest build your going to get
pitbullninja Posted October 16, 2011 Report Posted October 16, 2011 Bassstalker...if you have six 100 RMS subs then that's only 600 watts. Number of speakers/subs do not dictate current draw. On a note, if you need it to be cheap, why six 12"s? To provide a suggestion, Pioneer Championships. edit: cheap amps. Um...knowing what woofers, voicecoil configurations, and power would be very important factors. i was figuring in that he would need 2 possibly 3 amps. and most stock electrical cant handle more than 1000 watts. My friends running 4400 watts on stock although he's got a hemi so the alt is prolly pre-upgraded I call bullshit on that one man, I have a cummins and it's a lot bigger than the hemi, still the same 140amp or so alt and my truck even has two stock batts and the big three and I have a decent amount of voltage drop on 2k when I go full tilt, enough to have to turn it down for sure But I'm not... I saw what I saw he has a magnum or something like that idk what the cars called but the amp is 4k no extra batts or Nything. He does have a large cap tho Just because an amp says 4000 watts on it does not mean that the amp makes 4000 watts, and even if it did actually do rated he could have it wired at 1ohm. But there is no way that you are getting 4000watts out of stock electrical, it's just not possible. You've been tricked bud 2ohms and I don't get it.. It's not like he's trying to trick me...
kam311 Posted October 16, 2011 Report Posted October 16, 2011 He doesn't have to "try" and trick you, you just trick yourself. Anyways bottom line is it isn't possible on stock electrical, your either confused or lying.... And to the op, don't buy wal-mart dual subs, that a horrible suggestion by someone that probably shouldn't be suggesting things on here. Best suggestion is a nice 2 sub set up with two good subs and a good amp. You don't have to have "six twelves" to be louder than your friends. You could do it with 1 8" if you knew what you were doing. so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
