true power rating?
qcbangin
i've heard a few times that you can get your true power ratings with a formula using the fuse ratings of your amp. does anyone know this formula? my amp uses 5X 40amp fuses. it claims to be 3200rms, but i know it's not true. i'm just looking to find the range my amp is pushing.
only real way of knowing exactly what your amp is putting out is clamping it
but multypling your fuse rating by 10 can give you a rough estimate on what you SHOULD expect, however it isnt the most accurate, IIRC every 10a of draw should be about 100w rms.. 4 x 30 a fuses = 120a, x 10 = 1200w rms... yours is 4x 40a fuses = 200a = 2,000w rms.. but like i said its not accurate, could be more.. could be less especially after voltage loss and impedance rise
but i cant remember the last time i owned a sub amp that had on-board fusing lol
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
im pretty sure to get a rough estimate of what your amp can POSSIBLY do is add the fuse ratings and multiply by ~10. so this amp can do ~2000 watts at best.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
^^ yea thats the right formula. theres a more complicated one involving voltage but this one works too.
thanks for the help. like i said, the amp claims 3200@1ohm, and i'm running an AQ hdc318, and didn't want to blow it. i knew it wasn't doing near rating, just wanted to get a number closer to reality. will defenitely be rewiring down to 1ohm tomorrow.
Does W = V x (V/R) work for those without a clamp?
W=Watts V=Volts R=Resistance.
I tried that on my Alpine M-1000 and got 1200 RMS... that seems realistic to me?
Edit: @OP: What amp is it?
also that HDC3 should be able to handle 3200 watts as long as its clean unclipped power. just an fyi if you ever upgrade your amp
Build Thread
UBL
1948 Plymouth
Ya I use rough estimate by multipling the fuse rating x 10 x efficiency % then accounting what ohms u r in
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
  • Who's Online   0 Members, 0 Anonymous, 569 Guests (See full list)
