adreano17 Posted October 28, 2011 Author Report Share Posted October 28, 2011 We cant help you if you cant help us getting the info.... what info do you need exactly? Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow Link to comment Share on other sites More sharing options...
AmericanLegend Posted October 28, 2011 Report Share Posted October 28, 2011 I worked for Best Buy for a while and, when I got there, the lead autotech was building boxes off of specs recommended by kicker. They sounded horrible! The customers that paid custom money for those boxes got screwed because they don't play low bass with that small box and high tuning. You had better design a box to your sub with help from somebody on the forum before you waste your time building a woofer (not SUBwoofer) box.... Quote Link to comment Share on other sites More sharing options...
OrionStang Posted October 28, 2011 Report Share Posted October 28, 2011 Is that 30sq in of port for the 4.2cube box? Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
adreano17 Posted October 28, 2011 Author Report Share Posted October 28, 2011 Is that 30sq in of port for the 4.2cube box? no, thats for the 2.1 Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow Link to comment Share on other sites More sharing options...
ryan916 Posted October 28, 2011 Report Share Posted October 28, 2011 No I think he recommended the 30 for the 2.1 cubes which is right in the rule of thumb area. Punkrok not sure why you think its a problem Quote Link to comment Share on other sites More sharing options...
cjvue Posted October 28, 2011 Report Share Posted October 28, 2011 I've always have great luck with 12-14 sq in per cube on the 15". I don't know if the 12's would be the same. Quote My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio Link to comment Share on other sites More sharing options...
IH8PunkRok Posted October 28, 2011 Report Share Posted October 28, 2011 No I think he recommended the 30 for the 2.1 cubes which is right in the rule of thumb area. Punkrok not sure why you think its a problem because he keeps being vague and i thought it was total port area. Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
adreano17 Posted October 28, 2011 Author Report Share Posted October 28, 2011 No I think he recommended the 30 for the 2.1 cubes which is right in the rule of thumb area. Punkrok not sure why you think its a problem because he keeps being vague and i thought it was total port area. i didn't think i was being vague. what exactly do you need to know to better help me? Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow Link to comment Share on other sites More sharing options...
IH8PunkRok Posted October 28, 2011 Report Share Posted October 28, 2011 the box will be fine. build and be happy k? k. Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
fueledbysound Posted October 28, 2011 Report Share Posted October 28, 2011 for peak performance for loudness 2.1 cuft/sub tuned to 38-40 hz.....!? The optimum enclosure is more like 3.75 cu. ft. per 12" L7 with a large port. I cannot remember the size of the port but if you call over there to Kicker they will give you the dims (don't ask a sales rep, they don't know). If you are lucky and anyone is left at Kicker that knows anything about car audio then they will give you the hot setup for that sub. I have built many of them used in PA systems at events and in event semis and they crank with big QSC amps running them. If you want to get straight to the best source there at Kicker, try to get a hold of Kip. If you can't get him then try tech support but good luck. Quote Daewoo Leganza with Commodore 64 installed in the dash. Link to comment Share on other sites More sharing options...
