We cant help you if you cant help us getting the info....
what info do you need exactly?
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
I worked for Best Buy for a while and, when I got there, the lead autotech was building boxes off of specs recommended by kicker. They sounded horrible! The customers that paid custom money for those boxes got screwed because they don't play low bass with that small box and high tuning.
You had better design a box to your sub with help from somebody on the forum before you waste your time building a woofer (not SUBwoofer) box....
Is that 30sq in of port for the 4.2cube box?
no, thats for the 2.1
I've always have great luck with 12-14 sq in per cube on the 15". I don't know if the 12's would be the same.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
No I think he recommended the 30 for the 2.1 cubes which is right in the rule of thumb area. Punkrok not sure why you think its a problem
because he keeps being vague and i thought it was total port area.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i didn't think i was being vague. what exactly do you need to know to better help me?
for peak performance for loudness
2.1 cuft/sub
tuned to 38-40 hz.....!?
The optimum enclosure is more like 3.75 cu. ft. per 12" L7 with a large port. I cannot remember the size of the port but if you call over there to Kicker they will give you the dims (don't ask a sales rep, they don't know). If you are lucky and anyone is left at Kicker that knows anything about car audio then they will give you the hot setup for that sub. I have built many of them used in PA systems at events and in event semis and they crank with big QSC amps running them. If you want to get straight to the best source there at Kicker, try to get a hold of Kip. If you can't get him then try tech support but good luck.
Daewoo Leganza with Commodore 64 installed in the dash.
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
