is the re audio box calculator accurate
.75x2 = 1.5
So the port height would be 19.5
Are you doing a side slot port?, if so remember to put "3" in the # common wall box. And add the woofer displacement, it will change tuning slightly.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
ok this is what i'm up to now. and everything should be correct i hope Untitled-1.png
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
azagtoth is correct. also, box height 2 and box depth 2 only need to be filled in for slanted boxes. if all sides are straight, you can leave them blank
On torres' calc you have to put 3 common port walls for a slot port. Also, port area is off because you didn't account for wood thickness, so your port height on torres should be 1.5 inches.
1.5 inches tall? i thought it was the height of the box minus 1.25 inches because the wood is .75
Oh sh*t, my bad,19.5 inches(# nine gets jammed on my keyboard sometimes), like azatgoth said.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
dbl post.
its all good bro i f$#%ed up the math anyway it was 1.50 instead of 1.25.
  • 10 months later...
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
