DC Sound Lab
Ill be waiting for new numbers :popcorn: :popcorn: I hope we see a gain. :drinks:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
thats a nice score jump for sure. hope you break a 157 soon. good luck.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Ever thought of using bigger speaker wire now with the 12k because the wires are longer
Nice of you to mention that. I have 8g to 4g adapters on the speaker outputs then its spliced to true 8g wires hooked up to my subs. Even though the output wires are 8g inside the amp my amp guy is goin to upgrade them to 4g on th inside plus beef the protection relays and add burr brown technology to the board
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Running duals u should see an .5 gain easy.with ur electrical. Just to be safe stick at .5 we know its.safe there.. Id like to see if there is any gain or drop from running 8ga straight.from amp to subs thats what Iam doing just had no point to compare.
OREGON STATE REP DCAUDIO & JUICEBOX BATTERIES
2x 15 DC Neos...
1 DC 9k
2 Sets of Hertz MLK 2 Mids with Scan Speak Tweeters
Zuki Audio Eleets
2x multicells
4 Runs of 1/0 back
2010 Subaru Outback
What's the math like 70plus amps and over 100volts its a no brainer. When I strapped 2 9ks at .7 in my hoe and hooked it up to 12 -12s in the pooper it burnt the 12g speaker wire off the terminal of 3 subs
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I dont know if its overkill or not but I am using 4ga to run from my amp in the bed of the truck into the truck to the bolts that I am using as terminals. I would rather over do something and know that I have plenty then to try and just get by and have to go back and redo something.
I'm a electrician by trade and I always run as much or the biggest wire I can in car audio applications. Were its lower voltage and higher amperages. Bigger is better and less resistence.. especially with the wattage we are running.. slap those xls in there cj. Just use some gorrilla tape or goop on those surrounds temporarly. I want to see the results going from the 3s to xls on the same power. Is the ohm load the same?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Cant wait to see the Hoe in the lines and get a demo.
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Gained .3 with the dual inputs so I got a 155.6 back still searching for more dbs. Tried playing with port and lost..
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I think you will be able to get it :D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
