Im looking to get 2 18" BTL N2s and strap 3500 watts to both in a Pontiac G6 GT. I was wondering will a 320 amp H.O alt and a XS Power DS1200 under the hood and 2-3 DS3100 be enough to keep a decent voltage
Yes, looks good to me.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
thats more than enough to back it up. I have a single smd 18 powered by a dc 5.0k amp wired to .5 ohms nominal rising to at most 1.2 ohms, its usually rised to .78-.8 ohms though. I have a 270 amp mechman alt, and a single xs power s3400 battery up front with 4 xs power d3100's in the rear next to my amps. If i have my engine above 1500 rpm's i dont get any lower than 13.78 some odd volts but if im at idle which for me is 600 rpm's i get the drop down to 12.9 if i keep it at full tilt and slam for longer than 5 minutes. I only did that once just to test how much of a load my alt could take at idle but i refuse to bass at redlights because for one it pisses everyone off who cant get away from my loud ass truck and two it kills my alt from that heavy load it cannot produce at idle. Now are you going to get something like an aq3500 for your two btl's? Is that what you mean by strapping them together or are you getting two amps to strap and get around 3500w rms? Also what ohm are you strapping it down to?
For me what id say to do would be to get the alt in there first if you are hard on a budget and get as many batts as you can. For the one you can fit under your hood id prefer to have nothing lower than 2 d3100 batteries but would prefer to have 3 just as extra reserve and if you plan to bump with the car off. I have played my system at full tilt with my truck off for an hour and a half once and never fell below 12.6v when the batteries usually rest at 12.8v so i think thats pretty good for how long i was slamming on them.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
3500 per sub, right?
Yes it would be 3500 watts per sub. I was planning on running two Audioque 3500D. But since Im still somewhat of a noob when it comes onto some things. How would i go about strapping the amps together, what way would be best, and what ohm load would the amps be at ?
@ AMI CUSTOMS Would getting 4 15" FI Bls be as loud and or louder than the 18s due to more cone area?
Im just trying to figure out what setup I want. I have owned both the BL and BTL and they both are great but I prefer the look of four vs 2 big 18s. If i chose the 4 would that mean more batteries? Also does anyone know where I can get a custom dual alt kit bracket made?
I assume you are going to do a wall?
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
4 15s if given the proper air space would be louder then 2 18s, in almost any setup. Two 3500d.1 strapped at 2 ohms wouldn't require any more batteries then what you listed, if you wanted better then 13 volts full tilt you would need 4-5 d3100s or more alt output.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 2595 Guests (See full list)
