How many D3100s do i need
Yes, looks good to me.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
thats more than enough to back it up. I have a single smd 18 powered by a dc 5.0k amp wired to .5 ohms nominal rising to at most 1.2 ohms, its usually rised to .78-.8 ohms though. I have a 270 amp mechman alt, and a single xs power s3400 battery up front with 4 xs power d3100's in the rear next to my amps. If i have my engine above 1500 rpm's i dont get any lower than 13.78 some odd volts but if im at idle which for me is 600 rpm's i get the drop down to 12.9 if i keep it at full tilt and slam for longer than 5 minutes. I only did that once just to test how much of a load my alt could take at idle but i refuse to bass at redlights because for one it pisses everyone off who cant get away from my loud ass truck and two it kills my alt from that heavy load it cannot produce at idle. Now are you going to get something like an aq3500 for your two btl's? Is that what you mean by strapping them together or are you getting two amps to strap and get around 3500w rms? Also what ohm are you strapping it down to?
For me what id say to do would be to get the alt in there first if you are hard on a budget and get as many batts as you can. For the one you can fit under your hood id prefer to have nothing lower than 2 d3100 batteries but would prefer to have 3 just as extra reserve and if you plan to bump with the car off. I have played my system at full tilt with my truck off for an hour and a half once and never fell below 12.6v when the batteries usually rest at 12.8v so i think thats pretty good for how long i was slamming on them.
3500 per sub, right?
Yes it would be 3500 watts per sub. I was planning on running two Audioque 3500D. But since Im still somewhat of a noob when it comes onto some things. How would i go about strapping the amps together, what way would be best, and what ohm load would the amps be at ?
@ AMI CUSTOMS Would getting 4 15" FI Bls be as loud and or louder than the 18s due to more cone area?
Im just trying to figure out what setup I want. I have owned both the BL and BTL and they both are great but I prefer the look of four vs 2 big 18s. If i chose the 4 would that mean more batteries? Also does anyone know where I can get a custom dual alt kit bracket made?
I assume you are going to do a wall?
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
4 15s if given the proper air space would be louder then 2 18s, in almost any setup. Two 3500d.1 strapped at 2 ohms wouldn't require any more batteries then what you listed, if you wanted better then 13 volts full tilt you would need 4-5 d3100s or more alt output.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 646 Guests (See full list)
