good to see another audi on the board! sorry i cant help with the wall though
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
I think you need to get more experience before walling your car.....
why would you comment, if you have no prior experience in building a wall?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
thanks for the help. didn't come here to get responses like this. i know what im doing. this will be my first wall but i have enough experience to tackle this..
the best thing would be to have someone make u a design
look thru ppl build logs and take notes, look closer at similar walls to what your planning so you have an idea of what you will have to do
oh and make sure u wont used your car for more than getting around lol you wont have room to do anything else
so what do you need help with then?
You need to do a ton of measuring. Then build a frame of 2x4's bolted to the car. Then layer MDF over the 2x4's to make the "box". Cut your baffle to fit tightly to the shape of the car, OR make beauty panels that fit between the box and the car to seal it off.
Use the search button, check out the build log section, and use google. :good:
SMD Super Seller
My Feedback Thread
would it be better to make an actual box? because there is sheet metal between the cabin and the trunk. and also a gas tank. i was thinking about making an enclosure just in the backseat. which do you recomend.
  • Who's Online   0 Members, 0 Anonymous, 3006 Guests (See full list)
