Thoughts about smaller cone but bigger motor vs bigger cone and smaller motor
Ok sorry ahead of time if i get long winded here lol. Ive been going back and forth on my next build for a damn year now and heres where im a bit stuck. I either want to do a single DC 15" on a dc 2k or a single 12" dc lvl 5 on 2 dc 2ks strapped. Id want to do the xl because i loved my old xl 15 and know what box size works and fits in my trunk. However ive been thinking the lvl 5 12 to try something dif than before. I would also have more space taking that route to build a beefier and more efficiant box but wouldnt have to cone area of the 15. So wonderin what yall think and why. What benifits other then what i already know should i consider. They are both beasts in my book and know id be happy either way but either setup is alot dif from eachother. Ok im done blabbin lol
Edited by cracker
more cone means less excursion to for the same output and also gives the ability to go lower frequency wise before running out of excursion, assuming each uses a similar coil/motor setup that can attain the same excursion levels. 15mm xmax 15" vs 25mm xmax 12" would be a toss-up for example.
Motor all depends on the design of the motor and the coil. Could be a tight gap or a loose gap, not to mention depth, back-plate design, pole design (solid vs ported), and top plate design..
Tons of things to consider.
Hammerdown... 1%
^^^ :good:
Like was mentioned above, there are MANY factors that play into this but on the theoretical note:
Doubling power = +3dB
Doubling cone area = +3dB
You're not quite doubling the cone area by going from 12" to 15" but you might be close with either solution.
Again theoretically +10dB is considered to be perceived as being twice as loud. This requires increasing power by 10x...
:shrug:
I say do what makes you happy and go with it.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
The old saying goes,
"There's no replacement for displacement"
www.phoenixphorum.com
Setup
HU: Eclipse AVN6620
Amp: Audison LRx5.1k
Mids: 6 1/2" Silver Flute's
Tweets: Clarion SSS601
No rears
Subs: (2) TREO SSi12.22's
Processing: Audio Control DQS, Phoenix Gold BassCube
Clarion Collector
HEAD UNITS:
7770 w/920EQ w/2nd 920EQ display
ADCS-1 w/CDC605
5780CD
DRX9375r w/DPH9300
DRX9575Rz w/DPH7500z* (*1 of2)
DRX9675z (2X)
AutoPC 310
HX-D10 w/DPH910
DXZ615 w/DPH7500z* (*2 of 2)
CDC655
DRX8275 w/DPH9100
DRX7475
5632CD
AMPS:
A007-w
1800A
A1200
A500
APA4200
APA4320
APX400.4M
SPEAKERS:
SSS601 (2X)
SRC4650
SRC5752
SEC571
SEW5107
Ok so what im gettin is i could prob get close to the same output and or sound either choice, just depends on what space i want to give up for build or equipment? I thought about the level 5 15 too trust me lol but considerin i cant give up the whole trunk and would need more amps and batt with any size level 5 over the xl id go with the 12 there. Hmm, thinkin keeps on goin lol. I plan to start buyin equipment after the new year so theres still time to decide. Anybody ever hear the 2 dif subs in person by chance? The xl 15 and level 5 12. Im thinkin with the monster motor force of the level 5 it just has to be a mean lil shit. Ive had the level 4 15 and xl 15 to compare and damn the xl just was on another level ha
I've owned xl 15's and a 5 12. The single level 5 got down on a 3.5k, hit lows and got loud. And that was in a less than ideal enclosure.
When I had two xl 15's(on a Stetsom 7k), it was way louder, they were in an ideal enclosure though and there were two of them. The xl's do sound a little 'cleaner', don't want to say more sq, but they are smoother.
XL 15 on 3.5k is my vote.
SMD Super Seller
My Feedback Thread
Ok i hear ya orionstang. With the amp choice id do the 2ks out of price to the 7.5k and will most likely pickup one of them before making a final decision on sub. One thing i should also add is the enclosure i could build for the xl 15 would lack a few things due to size. I couldnt add 45s to the corners and not much bracing at all, single layer everywhere but the front where i could double it. With the level 5 12 id have room to double layer all around, add bracing and 45s in the corners. Id also have more room for more port. Im not out for sq i just want it to hit hard n get pretty damn low. Thanks for the responses and i will def be considering everything thats been said
  • Who's Online   1 Member, 0 Anonymous, 1203 Guests (See full list)
