Long Ports Inefficient?
OrionStang
Don't forget that long ports will begin to act like a t-line at certain frequencies. They will begin to develop their own resonating frequency if you start to get too long
er, thats the main point of a port
Hammerdown... 1%
As in the port will develop it's own resonant frequency separate from the rest of the box and it's designed tuning point. Could give it a muddy sound.
in that case its just poor port design
Hammerdown... 1%
Okay. Right. That did seem to make an improvement of a DB or two....
Peace,
Fish
Hey Gaming, I'm just curious as to why I (or my system) would be an example ? I think mine plays pretty darn loud and clear. Of course I'd like more... Wouldn't we all ? :)
But anyway, I have three 6" dia ports, with a length of 30" each, for a tuning of around 31 hz, and again, I'm pretty happy with it. Would like to triple my power, but..... :)
The only thing I'd do different next time, is to run a single, larger vent > but keep in mind, if I wanted to go with the same sq inches of port that I have now, that vent would also be 30" long. If I wanted to bump it up to say 30% more port area (for longer throw subs) the vent would probably jump to 45" ! And I believe, it would still sound perfectly fine, as long as it were tuned correctly....
But come to think about it, I believe somebody already said that.... So, I concur :)
Peace,
Fish
I think (don't quote me on this) that a long port like that reduces the sound quality (Fish Chris as an example)t. As far as efficiency goes, I don't believe so, but... I can't really say for sure.
It was when you had the different length ports coming out of your box, and you eventually chopped them down to (I believe) 6" each, and you said it sounded better. That's what I was referring to.
On slot ports height and width should be kept no more than 9:1 relationship or there will be losses on the corner due to excessively narrow port.
Also there is an equation for minimum port area, this is to limit the airflow speed on the port. Losses on the corner if I remember right increase in a non linear way as airspeed go up but you may want to better research this.
And yes if you tune your port low you will waste energy playing near subsonic frequencies.
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
