Sounds like a clogged cat, try taking it off and cleaning the honey comes out of it or replace it. Its not able to get rid of the back pressure, that always makes cars act funny.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Sounds like you have a fouled out MAF or a bad TPS. It also could be the fuel filter if you've never changed it and you have over 100k miles then id go ahead and do that. Do any check engine lights come on?
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
Plugs gapped correctly? Proper heat range? Timed right? It's missing. May have a faulty coilpack.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
im thinking this might be it but ill check for the other things too
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
By the way it sound on one of your videos wshen you go to the exhaust. And you hear a ticking? Sound like it. Could be. Lifters are bad. Or. You spun a bearing or even its worn out. Had the same problem in the blazer a swhile back does your check engine blink only when you hit the gas. ? And does do it stay solid till you get over a certain rmp?
coil packs! 3800 series II motors like to kill them from time to time like Eric said, as for the timing, these are interference motors if it jumped time chances are it would bend the valves and smiley the pistons and only run for a short time, cat is possible but normally doesn't happen all of a sudden, if it is the cat REPLACE it, OBDII will insure poor performance and bad gas mileage if you remove/hollow the cat. jmo hope it helps
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
isnt that the same engine thats in the bonnevilles? the 3100? if it is i would also check for a intake manifold leak..... those engines are known for it. usually when it goes it sucks in antifreeze and itll spin a bearing....but itll run kinda like that. also hows ur power steering pump? sounds kinda whiny lol js :)
lifters are usually pretty noisy on those engines also so thats probably the ticking your hearing.
i work @ south windsor auto parts (salvage yard) so i see these engines ALL the time.
take it to autozone for a free check engine light diagnosis and see what the code says. its flashing so i would be a little worried about wasting too much time as things will get worse......
just my 2 cents :)
-jarrid
ps- let us know what happens!
edit DUR- if i read ur sig i wouldve known it was a 3800 as its the 3.8 liter.... but still same design.....my thought doesnt change lol
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Might want to check timing and see if it jumped a tooth as another possibility.
I was thinking more ignition timing, but with a coilpack it'd use a crank or cam sensor. Also another thing to look into.
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
  • Who's Online   0 Members, 0 Anonymous, 408 Guests (See full list)
