S-10/Blazer HO alternators, Battery Banks and Wiring
  • 9 months later...
00 blazer dc 270xp one run kicker 1/0 hyperflex stock batt and dd m2a at .7 never dropped below 12.8 at idle
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
Dual Mike Singer 350 amp alts, 6 runs of True 2/0 welding cable, XSpower d4300 up front, two xspower xp 3000 and four deka group 31's. I have 4 DC 3.5k's. I can demo non stop. I have seen it drop to 12.2v with a 2k rev. I charge at 14.8 but i bump it up to 15.3 while demoing.
Running a DC 270sp on a 98/99 2.2 ext cab. It over complicated because im running 2 14v batteries in the back and 1 BT20 in the front. Charging @16.7ish cold and stepped down for the car electronics.
2 runs of knu 1/0 ofc from alt to rear. 2 runs of knu 1/0 ofc ground to the block.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I have a stock alt (soon to be replaced) stock front batt (soon to be replaced) running (2) SA 15's & Skar 1500.1 with a Shuriken BT-100 in the rear, big 3 all 1/0. Got it to where im only dropping to high 12'setc, need to upgrade soon!
  • 2 months later...
  • 1 month later...
Jon,
Thanks for turning me on to this thread man!!!!...
I looked on the XS site, and they recommended a D925. But, everyone im seeing is able to jam a D34hun under the hood. Am i high? Or not understanding something here?
Thanks in advance guys !!!!..
Im glad to be apart the blaze crowd...
99, 4.3
Also, Jon, your ac unit, and alt are backwards !!!! lol...
