Basics of a 4th order bandpass enclosure
donellk
Im going to build one, screw it if i blow the woofer.
2x6" aeros enough for a 12?
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
i really REALLY wish people would stop hugging up to the whole ratio thing.
dumbasses squeezing down the sealed side in search of a higher ratio/more peak.
Seriously. build the sealed side to spec/desired F3. then build ported side to accomodate taste. peaky or flat is up to you.
Throw the whole notion of ratios out the damn door.
So what you are saying is just build the Ported side to your liking?
My 4 12's are in a sealed box right now but i have two seperate chambers for each pair of subs, could i turn this box in to a 4th order?
this is a great start to get over that first hump of how to design bandpass. i have a small understanding myself, but would like to know more.
i'm curious as to what the tuning of the ported side does to the box. with regular ported 30-40hz tuning is kind of the norm.
but since you say tuning higher is pretty standard, what are kind of the norms, and what does that mean for sound?
also i think you could go into more depth on what passband is.
my understanding is that the lower the ratio (i.e. 1:1) the larger the passband and the more musical it is over a broad spectrum of frequencies.
the higher the ratio (i.e. 1:3 and up) the smaller the passband. which translates to a peaky, but louder box.
would love to see some experts chime in here and fill in some gaps. great reading!
More box builds
I'm with captain stupid.
I'm not really an expert but I can try fill in some gaps. The reason you can tune higher with a 4th order is because the sealed chambers control the low frequency cutoff where as in a ported box, the port controls the low frequency cutoff. Normal tuning is between 45-55 bit people go higher and lower than that.
The passband, or bandwidth is the space between the upper and lower f3 points. With a smaller ratio (1:1) you'll have a wider bandwidth but lower output. With a higher ratio (1:3) you'll have less bandwidth but more output.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Thanks everyone! If u have any question I'll try to answer them the best I can like I said I'm not a expert!
As for the ratio I wouldn't sacerfice a lower f3 to have a dead on ratio but I prefer a flatter response for daily listening! But that's another thing that would be up to the builder!
Team Xtreme Amperage
Xtreme Audio Innovations
XtremeAudioInnovations.com
Facebook.com/xtremeaudio321
4 linked c notched bagged
Fiberglass door panels (5 speakers per door)
my biggest concern is how do you know if a woofer will work well in a bandpass enclosure? please explain this detail for me and others.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I normally go by having a low Fs and having a qts of over .4
Build Thread
UBL
1948 Plymouth
  • Who's Online   0 Members, 0 Anonymous, 1829 Guests (See full list)
