Sub barely moves?
cant set ur gains with a Dmm....
You can, But its not guaranteed to not clip at some point.
Are you wired correctly?
And only 2V Preout, I'd say the gain might have to go up a bit. But still, Best bet is to get a DD1 or a Scope and check it. Then set right.
Also gotta throw this in:
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Hey man in the initial settings make sure you chose the rear RCA's output set to sub and not full output. Also make sure that you don't have the HU low pass set to something super low like 50Hz
alright i'll have to check my LPF on my h/u and my amp tomorrow. for using a dd1/scope i dont have the money to buy a dd1 or know anybody that has a scope..so the best i can do is use a dmm. and for being wired correctly? I think so xD.
Fi X12
AQ750
Pioneer DEH-6300B h/u
Check your subwoofer output settings on the deck, some have to be raised to put out the "rated" power to the amp so you dont have to max out the gain on the amp.
Hammerdown... 1%
you said you have an audioque 750. does the red clipping light on the remote knob ever come on when you play music?
oohhh shit i completely forgot about that remote. its probably still at in my amp box. i'll put that in tomorrow and report back
Fi X12
AQ750
Hey Kanny if i have my gained turned all the way up and the clipping light never comes on would it still be bad to have my gains up so high? because thats really the only way my sub starts slammin...i dunno what to do lol
Fi X12
AQ750
the sub level on the headunit isnt up probably. i'd bump it up one notch at a time til that light comes on.
edit: people are probably gonna argue that the clipping light isnt 100% accurate, which it isnt, but you really dont have a more accurate method available.
On my head unit i got SW Settings 1 & 2. the first settting is just Normal-Off-Reverse. I have it on normal. the second setting i dont think says anything its just like 100hz:0 80hz:0 ect.
On my amp should i mess with the subsonic filter or leave that one alone?
Fi X12
AQ750
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
