you should post this in the Fi section so nick will be able to see it, but im sure it could easily handle 3500 just make sure you set gains correctly
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
2500rms
"If you need to ask..."
I'm kidding.
Hook it up, give it a clean signal, then play it. If you smell stinky coil, then back off. If not - then it can take it (should be able to)
That's always been my approach. I don't even go by rms ratings anymore haha. I reference then, but never listen to them.
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 2500W | 2500W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth:11.750” | 11.750”
Displacement: 0.26cuft | 0.26cuft
Currently a 10-15 business day machine/assembly time.
Plus 2-5 business days ship time via UPS ground.
Click to see the dustcap colors.
Product code: 0024118
Price: $ 494.00
  • Who's Online   1 Member, 0 Anonymous, 1310 Guests (See full list)
