PaCiFiKbAllA Posted December 14, 2011 Report Posted December 14, 2011 Do us a favor. Buy yourself a DD-1, set it, and forget it. 1 x Fi Audio SP4 V2 12" D2 Fully Loaded 1 x Wolfram W-4500.1 2 x XS Power D5100's 250A Singer Alternator 2.67 Cubes @ 29hz
sprkn_ranger Posted December 14, 2011 Report Posted December 14, 2011 should i keep the my 1200 amp or get a sundown 3000k amp and run it at 2ohm, but i gotta get another battery right? There's more to it than just getting another battery, you might be able to get away with it but you have to be able to make power to have power. The batterys just store what power your alternator makes and if your system uses more power than your alternator makes then eventually your battery's wont be able to keep up and you'll get voltage drop. I'd start with a stronger alt before adding battery's, especially if you play loud for longer periods of time. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
BassMunky Posted December 14, 2011 Author Report Posted December 14, 2011 should i keep the my 1200 amp or get a sundown 3000k amp and run it at 2ohm, but i gotta get another battery right? There's more to it than just getting another battery, you might be able to get away with it but you have to be able to make power to have power. The batterys just store what power your alternator makes and if your system uses more power than your alternator makes then eventually your battery's wont be able to keep up and you'll get voltage drop. I'd start with a stronger alt before adding battery's, especially if you play loud for longer periods of time. if i get the sundown 3000z and run the gains really low will i be ok?it will run at 1 ohm with my subs Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
CleanSierra Posted December 14, 2011 Report Posted December 14, 2011 Do us a favor. Buy yourself a DD-1, set it, and forget it. ^^^^What he said. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted December 14, 2011 Report Posted December 14, 2011 should i keep the my 1200 amp or get a sundown 3000k amp and run it at 2ohm, but i gotta get another battery right? There's more to it than just getting another battery, you might be able to get away with it but you have to be able to make power to have power. The batterys just store what power your alternator makes and if your system uses more power than your alternator makes then eventually your battery's wont be able to keep up and you'll get voltage drop. I'd start with a stronger alt before adding battery's, especially if you play loud for longer periods of time. if i get the sundown 3000z and run the gains really low will i be ok?it will run at 1 ohm with my subs What coil configuration are your subs? Im not the one you want to try to troll. Just a fyi for you.
BassMunky Posted December 14, 2011 Author Report Posted December 14, 2011 they are dvc 1ohm right now running diehard battery 0 gauge power ground 2 a splitter to 2 4 gauge wire big 3 0 gauge wire. voltage sits from 13.6-13.9 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
CleanSierra Posted December 14, 2011 Report Posted December 14, 2011 You can run them at 4 ohms final load or yes, 1 ohm final load at the amp. You need someone to help you properly set up your stuff, especially if you're at all considering that Sundown 3000. You can't be sending clipped signal to those subs, or you'll kill em. Im not the one you want to try to troll. Just a fyi for you.
BassMunky Posted December 14, 2011 Author Report Posted December 14, 2011 if i runt it at 4 ohm the subs willl be seeing only 800 watts. I was thinking if i run it at 1 ohm and have the gain really low i will be ok with the setup i have now?and the electrical i have? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Nine8SST Posted December 14, 2011 Report Posted December 14, 2011 should i keep the my 1200 amp or get a sundown 3000k amp and run it at 2ohm, but i gotta get another battery right? There's more to it than just getting another battery, you might be able to get away with it but you have to be able to make power to have power. The batterys just store what power your alternator makes and if your system uses more power than your alternator makes then eventually your battery's wont be able to keep up and you'll get voltage drop. I'd start with a stronger alt before adding battery's, especially if you play loud for longer periods of time. if i get the sundown 3000z and run the gains really low will i be ok?it will run at 1 ohm with my subs A DD-1 is under $150......what are your subs and amp worth? 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500
BassMunky Posted December 14, 2011 Author Report Posted December 14, 2011 I think I blew the 1200 that why i am asking about the 3k Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
