Nathan @ XSpower Posted December 12, 2011 Report Share Posted December 12, 2011 If you replaced your stock ground, make sure it didn't have a plastic piece that was around the ground cable. Some vehicles have sensors in place around the cables and if that sensor is not there, then it is basically breaking a protection circuit built into the vehicles stock electrical system. This can mess up your electrical because the vehicle isn't able to get a full electrical reading. Also check and see what the voltage is coming off of the alternator under the hood and at the battery in the back. Quote Link to comment Share on other sites More sharing options...
Firemanes Comin Posted December 12, 2011 Report Share Posted December 12, 2011 That's a bunch of bill having to by a special gam charger just so you can charge it up before dropping it in. I don't have to charge up a fucking autozone battery before I install it. Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted December 12, 2011 Report Share Posted December 12, 2011 That's a bunch of bill having to by a special gam charger just so you can charge it up before dropping it in. I don't have to charge up a fucking autozone battery before I install it. you have no idea what u are talking about please stop posting Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Firemanes Comin Posted December 12, 2011 Report Share Posted December 12, 2011 Oh, I know what I'm talking about, fuck you Quote Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 12, 2011 Author Report Share Posted December 12, 2011 If you replaced your stock ground, make sure it didn't have a plastic piece that was around the ground cable. Some vehicles have sensors in place around the cables and if that sensor is not there, then it is basically breaking a protection circuit built into the vehicles stock electrical system. This can mess up your electrical because the vehicle isn't able to get a full electrical reading. Also check and see what the voltage is coming off of the alternator under the hood and at the battery in the back. It was just a piece of 4 gauge wire. No sensors around it. Since I don't have a agm charger, can I charge it with regular charger? Also, how long will it take to fully charge it? Voltage in the back is at 14 volts. Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted December 12, 2011 Report Share Posted December 12, 2011 If you replaced your stock ground, make sure it didn't have a plastic piece that was around the ground cable. Some vehicles have sensors in place around the cables and if that sensor is not there, then it is basically breaking a protection circuit built into the vehicles stock electrical system. This can mess up your electrical because the vehicle isn't able to get a full electrical reading. Also check and see what the voltage is coming off of the alternator under the hood and at the battery in the back. It was just a piece of 4 gauge wire. No sensors around it. Since I don't have a agm charger, can I charge it with regular charger? Also, how long will it take to fully charge it? Voltage in the back is at 14 volts. no use a amg charger, i have this sear charger works great for under 100bucks Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
sayhuh? Posted December 12, 2011 Report Share Posted December 12, 2011 Are you still running the Kinetik too? If you are mixing batteries, you should run a battery isolator. This will prevent your batteries from using each other to maintain a charge, which may be happening. If the battery you have wasn't charged and you add it to the mi, then it will suck juice from the other battery and alt, etc etc. Or something along those lines...if I'm explaining it right. Quote Blown Link to comment Share on other sites More sharing options...
KillaCam Posted December 12, 2011 Report Share Posted December 12, 2011 Whats a d3100? You need a yellow top or two and a cap. See if you can find someone with an agm charger to charge it. Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
Team_DC-Derrick Posted December 12, 2011 Report Share Posted December 12, 2011 Are you still running the Kinetik too? If you are mixing batteries, you should run a battery isolator. This will prevent your batteries from using each other to maintain a charge, which may be happening. If the battery you have wasn't charged and you add it to the mi, then it will suck juice from the other battery and alt, etc etc. Or something along those lines...if I'm explaining it right. thats only when using different types of batts, both xs and kinetik are deepcycle AGM.. if it was a wetcell or drycell, it would be a big difference no need to do that with this batt Quote The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 12, 2011 Author Report Share Posted December 12, 2011 Are you still running the Kinetik too? If you are mixing batteries, you should run a battery isolator. This will prevent your batteries from using each other to maintain a charge, which may be happening. If the battery you have wasn't charged and you add it to the mi, then it will suck juice from the other battery and alt, etc etc. Or something along those lines...if I'm explaining it right. Running just a D3100. Whats a d3100? You need a yellow top or two and a cap. See if you can find someone with an agm charger to charge it. Quote Link to comment Share on other sites More sharing options...
