Ive only had 3 systems in the past and i always ran off of 1 amp, i was going to try to run 2 nightshade v2 15s off of 2 saz 2500s strapped at 1 ohm each amp (2 ohm final) or just get a sundown 4500 at 1 ohm. I heard that you lose more power when you strap 2 amps but im not sure if thats true. Any input would be great
*i'm trying to SQL, both daily and competition, i'm trying to get a little more into competition next year
Edited by OrenB217
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
strapping elts you set one gain. and allows you to have one load. ive seen instances where a pair of strapped amps was stronger than a single amp as well
orion 1200ds strapped would do like 3600 watts
an orion 2500d does 3200 or so.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I never understood why people strap amps with a setup like your considering. If you have 2 amps and 2 subs, just put an amp on each sub at 1 ohm.
why is that?
true, its just something ive never done in the past and always like to get input before i try, maybe i should!
Team gg.
I would strap them, that way you may get more power out of the two strapped than running a single amp after rise.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Strapped or not, i seriously recommend you to use 2 smaller amplifiers, easier to sell, easier to fit in the car, if one of them broke down you still have some bass, on wich case, you can change parts from one to the other one until you find the problem on the broken amplifier and just fixed, i could keep going all day long hehe.
I used a Soundigital 8K , cadence C6 and another couple of big amplifiers, now i only use multiple small amps and i´m so damn happy :)
thats enough to convince me to strap, plus why not try something new lol, so i guess i need dual 2 coils and wire them in series, then take the positives on both subs and parallel them to the "master" amp and the negatives from both subs and parallel them to the "slave" amp?
Team gg.
Yes, dual 2 ohms coils and just strap the amps, positive from the subs to positive on the master, negative from the subs to positive on the slave, of course, not all amplifiers strap the same way but that´s the most commun way, i´ve been using 2 smaller amplifiers strapped for about 2 years now and i´m very happy :)
correct me if im wrong, but youll see more rise when you strap compared to when you use a single amp, or a single amp per woofer
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Might be why you aren't loud? :shrug: LOL
^^^^Couldn't resist.
BUT by strapping amps, the MAIN advantage is you are running a higher impedance, so total output current is lower and output voltage is higher, current kills!!! Voltage is a hugh PLUS!!! If you want me to explain it further I can, but that is the biggest benefit honestly.
Edited by AMI CUSTOMS
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 9332 Guests (See full list)
