Watch the video. It does this on all 3 RCA sets, with both the 40hz track and the 1khz track. The head unit plays both tracks fine going through the amps. Testing the DD-1 with the amps has the same result as CJ18's
Here is a short video of the DD-1
http://www.youtube.com/watch?v=g1NO44Hwp3s
The 3sixty.2 is still in the box.
maybe troubleshoot all minor possibilities.. voltage, connections, conductivity, etc
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
are you using the supplied RCA harness or your own? Some RCA's are too fat to fit due to the plastic case limitations. It doesnt have room for it to make full contact and can cause it to act funny if not fully inserted. Either way, dont worry, we will get to the bottom of this. I just contacted Tony. I can ship you out a brand new one today if we end up shipping that one back.
Follow my Tweet (Twitter)
I removed the top plastic part due to the size of the rca's, Just to try and eliminate everything.
The voltage.
you know, mine did that once. I checked the ground and bammmmm it was a bad connection. It hasn't done that again. I notice mine is really sensible to ground connection.
you say both the 40 hz and 1khz track did you try the 0 db track just to see if it will work. I had an issue with mine and it turned out to be not plugged in tight enough. tightened it down more and away we went.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I went back out and used the supplied harness, made sure I had a good ground, Same thing.
Track 1 and 2 are at -0bd
That's customer service!
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
cool just making sure.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 2214 Guests (See full list)
