LT.Smoke Posted December 30, 2011 Report Posted December 30, 2011 Trunk class 1- Can have up to 4 12's or other combo equalling the same cone area as 4 12's and power limit would be 5k(No batts in car or alts) Trunk unlimited- can do anything you can stuff in car( no limit to batts but everything MUST remain in trunk) Suv1- Same as trunk 1 Suv Unlimited- No limit but all equipment must be contained in cargo area Wall #1-10K limit Wall 2- No power limit (Must be tuned under 55hz) Music- Run what you brung heads up class... No power or cone area limit- Non wall class Music Extreme- Bring what you want to bring walled or not its heads up for the title on music- Both classes must be tuned UNDER 45hz Sq- Can run kick panels and all other speakers must be in stock location-Processors allowed sqExtreme- This is the baddest of the bad-Only your mind limits you in this class Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
TeamSDLuke Posted December 31, 2011 Report Posted December 31, 2011 street stock 0 to 1000 street stock 1000 plus street a street b street c street max wall street max non wall no wall 1 2 hatch no wall vans , suvs etc trunk class street , 1 to 2 batterys max , 1 to 2 amps , 1 to 2 woofers trunk class ss unlimited woofers batts , amps ss 1 2 ss 3 plus extreme 1 2 extreme unlimited woofers my 2 cents
OrionStang Posted December 31, 2011 Report Posted December 31, 2011 street stock 0 to 1000 street stock 1000 plus street a street b street c street max wall street max non wall no wall 1 2 hatch no wall vans , suvs etc trunk class street , 1 to 2 batterys max , 1 to 2 amps , 1 to 2 woofers trunk class ss unlimited woofers batts , amps ss 1 2 ss 3 plus extreme 1 2 extreme unlimited woofers my 2 cents I like this, although OP said 8 classes, not 15 lol. SMD Super Seller My Feedback Thread
TeamSDLuke Posted December 31, 2011 Report Posted December 31, 2011 to alter that i would say make the street classes into a street trunk 1 2 then a street hatch 1 2 eliminiting about 3 or 4 classes ,
OrionStang Posted December 31, 2011 Report Posted December 31, 2011 I say keep it how you put it. There SHOULD be a class for everyone. SMD Super Seller My Feedback Thread
alaskanzx5 Posted January 17, 2012 Report Posted January 17, 2012 ameature trunk class 1 and 2 hatch class 1 and 2 truck class 1 and 2 suv class 1 and 2 class 1 would be limited to 1 battery in stock location and stock alt with 2000 watts or less class 2 would be limited to 2 extra batteries and 1 ho alt with a min of 2000 watts both class 1 and 2 wouldnt have no limit to the amount of subs but all amps baterries and subs would have to fit in the trunk/hatch/back. for a truck in the cabin heigth limited to the bottom of the back window and for suvs have to have all seats in there stock location up right not folded down and cant be higher then the bottom of the back window. all testing done on music with 3 runs each at 30 sec a run extreme trunk hatch truck sub no limits to the extreme class but testing is done on music 2 30 sec runs has less runs them ameauter because if your in the extreme class then you should already know whats best on your system and i know you said 8 but gotta inlcude everyone #9 extreme burb with 10 sec runs judge pics track #10 class 1 and 2 class 1 has to have all speakers in stock location ( can be fiberglassed as long as speakers are no further then 2" away from the stock location ) class 2 has no limit t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
