My key gets stuck in my ignition
it could be a couple of things IMO.the ignition lock cylinder could be going bad,or it could the shifters park switch that engages and releases the key.id try putting a little dry graphite in the ingition lock cylinder and see if that helps.i have a question,does the cylinder move otherwise when you turn the key or is it just stuck in the off position
I can turn the car on and off just fine it just gets stuck on the accessory and wont budge to off when the battery is hooked up.
since the lock cylinder moves id almost bet its in the gear shifter.the bushings in the gear shift wear out and the slop prevents the pawl on the selector from engaging the key release contacts
What kind of car? Because it sounds like a ignition switch.
Read much??
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
make sure its all the way in park :shrug:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
  • Who's Online   0 Members, 0 Anonymous, 1163 Guests (See full list)
