Can an aq hdc3 take as much power as a fully loaded fi bl
impossible to tell you which will be better with X watts.
and the first part of the question doesnt even apply if you later ask which one is better with 1200 watts.
It would be a waste to get a sub that can take 3+ thousand watts to only put 1200 through it. You would be better off getting a lesser sub and putting the saved money into other thingd
3000 watts RMS? You'll blow both of those subs at that. AQ is rated at 1k and the fi bl is 1.5k.
The hdc3 can take well over 1k clean power daily.....
Many variables to that, box design, user's experience, etc. etc.
TDH FTW !!!
this..even if your throwing clean power at it if youre box design is off than you can still end up blowing the sub
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
