RyanJ Posted December 31, 2011 Report Posted December 31, 2011 Why hello everybody! I was wondering if anyone had the time to make me a simple box design / enclosure for a single Sundown SA-12 D4. It's gonna be ran off an AQ1200D. Eventually the other 12 will come into play. Just a simple box, nothing complicated or fancy. Just want it to sound loud and be easy enough where I can make it with home tools and some MDF from the store. Sooo.. Yeah if anyone has the time, that would be great. I have no idea how to do them and that's why I'm asking. Well thanks! Happy New Years ! MOB-MOBILE: 2005 Honda Accord 5-Speed System: (1) Sundown Audio SA-15 (1) MB Quart ONX1.1500D (1) Kenwood KDC-248U Speakers: -Rear Dash: (2) Clarion SRQ6932R 6x9's SOLD New MOB-MOBILE: 2011 G37S Sedan System:TBD Instagram (18+) : DabsWitaBudget415
RyanJ Posted December 31, 2011 Author Report Posted December 31, 2011 Also, it's been a while since I've been on SMD and I've forgot some info. With a single SA-12 600w D4, I would use 0 gauge or 4 gauge ? I'm going to purchase the kits off of KnuKonceptx and I was just wondering which I should buy. Eventually, I'm going to get another SA-12 and hook it up to the same aq1200D MOB-MOBILE: 2005 Honda Accord 5-Speed System: (1) Sundown Audio SA-15 (1) MB Quart ONX1.1500D (1) Kenwood KDC-248U Speakers: -Rear Dash: (2) Clarion SRQ6932R 6x9's SOLD New MOB-MOBILE: 2011 G37S Sedan System:TBD Instagram (18+) : DabsWitaBudget415
ChrisLun Posted December 31, 2011 Report Posted December 31, 2011 1.5 cubes with 22 sq inches of port area 2006 Dodge Charger (2) Kinetic 3800 (1) DC Power 270XP (4) T1-12D4 (1) T2500BDCP (2) T400.4 7.5 cubic ft. (2) 6 in ports thru the rear deck (2) T165.2 (2) T169.3
SQMonte Posted December 31, 2011 Report Posted December 31, 2011 Also, it's been a while since I've been on SMD and I've forgot some info. With a single SA-12 600w D4, I would use 0 gauge or 4 gauge ? I'm going to purchase the kits off of KnuKonceptx and I was just wondering which I should buy. Eventually, I'm going to get another SA-12 and hook it up to the same aq1200DI believe the AQ1200 has 4ga. inputs, that'll be plenty.If it was me I'd build a 2 cube box tuned to 33Hz 16 tall x 24 wide x 18 deep with a L port, 14.5 tall x 2.5 wide x 38 long Will bang! Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
2000s-10 Posted December 31, 2011 Report Posted December 31, 2011 im going to be building one soon. im doing closer to 2 cuft.. im using a 4" aero port tho at 33 hz.. im gunna be running my aq1200 at 1 ohm on one of them. good luck to you 1999 grand prix gt kenwood x994 head unit 1/0 big 3 all shok industry single run to the back New mid/highs coming not sure what Soundqubed q2200d at .5 (have) 2 soundqubed hdc3 12s (have) New box to be built.. sealed firing forward (yet to be designed) 200 amp alt not sure exact size or manufactor xs power batts
ChrisLun Posted December 31, 2011 Report Posted December 31, 2011 2 cubes before woofer and port displacement yes....2 cubes after...no, I woul go no larger than 1.75...any questions you can also ask DJ on team Nemisis 2006 Dodge Charger (2) Kinetic 3800 (1) DC Power 270XP (4) T1-12D4 (1) T2500BDCP (2) T400.4 7.5 cubic ft. (2) 6 in ports thru the rear deck (2) T165.2 (2) T169.3
SQMonte Posted January 1, 2012 Report Posted January 1, 2012 2 cubes before woofer and port displacement yes....2 cubes after...no, I woul go no larger than 1.75...any questions you can also ask DJ on team Nemisis DJ ain't the only person who knows what works for these subs Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
bdog Posted January 1, 2012 Report Posted January 1, 2012 i used 2.2cf before displacement on 600watts and couldn't be happier tuned to 31 REP
teardrop Posted January 1, 2012 Report Posted January 1, 2012 straight from sundowns web page Enclosure Suggestions: 1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz * Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes) * Enclosure can be as big as 2.25 ft^3 with lower power levels 1.00 ft^3 sealed -- F3 of 44 Hz * For SQ and space limited applications
Joe X Posted January 1, 2012 Report Posted January 1, 2012 Here is a design ready to build: Enclosure Specifications: Fb = 32 Hz Vb = 1,75 ft^3 External Height = 15 in External Width = 33,39 in External Depth = 12 in Port Width = 2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 30 5/8 x 13 1/2 Back = 33 3/8 x 13 1/2 Left & Right Sides: Side 1 = 11 1/4 x 13 1/2 Side 2 = 10 1/2 x 13 1/2 Top & Bottom = 33 3/8 x 12 L Port Internal Assembly Parts: Front to Back = 8 1/2 x 13 1/2 Extension = 23 1/4 x 13 1/2
