honestly regardless of how well you did big3 which sounds like you should be good, 350rms should not dimm lights unless your car is old as f**k and has like a 60 A alt or even less. sounds like a diff problem to me
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
On my phone right now and I'm having probllems with my internet so I cant upload pics. But some other things are that its a 90 amp alt, and This problem only exist while at idle, and it were a different problem with my truck what would it be? Any ideas?
Basshead-in-Training
If your alternator is not putting enough amps then adding a 1/0awg to it is not going to do anything. Sounds like either your battery is bad or your alternator is. A stock alternator should be able to put out enough amps for that amp with out the big 3 and with no voltage drop.
Suburban Build Log
"So much money and time spent making copper winding move up and down a magnetic pole"
DC Audio Eclipse
if you have spare wire, i would try putting a run from the battery to the fuse box. it couldnt hurt
How much is the big 3? Does it depend on your car and what gauge wire you use?
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
if i were you i would go to advanced auto and have them test your alt and battery, its free and if there both fine then u had to wire something wrong, cuz ur stock electrical should handle that with zero voltage loss, how did you do your big 3, maybe your ground are wrong, what i would do if anything is run 1/0g from your alt bracket[what holds the alt in place] and ground it to frame, hope im any help man
Think I might have to get the alt tested. It doesnt happen whe ln Im driving but the volt drop was from 14.4-13 or lower, on consistant bass. I actually have other problems with my truck, it might be related.. It takes 3-4 seconds to start but is very reliable, and also It tends to not Idle when I'm driving It runs perfectly except for these things. When I drive Im Finding myself putting it in neutral to keep it going, also it usually dies smoothly
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
