I usually do 15 or 16 inches of port per cube.
Was wondering for future box building use, what to use for port area since ive never figured out what this rule of thumb is really about or means i just use it since its recommended.
Can anyone explain it? for example when it concerns subs like kicker cvx, L7, skar, sundown sa stuff like that.
Thanks im really into being loud but sounding very clean as well and hitting all of the higher bass frequencies as well if this has any affect or whatever on port area.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Whats the difference if 2 boxes were say 4 cubes with a tuning of 32hz, same subs same power, but one with 16 inches of port area per cube and the other with 12 inches of port per cube?
IIRC bigger port means louder but peakier, less power handling below tuning point. Smaller port is just the opposite
And the port/cube is just a very general rule of thumb. How much port area a person 'really' needs is based off of air displacement by the sub(s) and tuning point
Edited by SnowDrifter
when i build boxes, i ask the person what kind of music they mainly listen to. If they listen to rock, country or metal, i'll do 12-13. I think it lets the bass guitar and kickdrums sound really nice. If the person listens to alot of rap, techno or dubstep, i'll do 14-16 depending on how much air they want to move.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
Do you know what is the method, rule, or just how do you come up with the right port area using air displacement and tuning?
For example a sub like a kicker cvx 15 or skar 15 vvx or sa 15 how do i go about determining what to use?
By peaky do you mean around the tuning or where?
"peaky" means a big hump in the frequency response just above the F3 point.
A box being peaky is not caused by the port size (unless it is undersized and has too much compression), the tuning frequency vs. the box size vs. the driver parameters will determine the frequency response. High Q designs will have more peak. Usually works out great in a car where cabin gain boosts the lower frequencies. That is why you see car subs tuned 30-35 Hz, but home subs tuned down around 20 with drivers that have different t/s parameters (or amps with EQ on the lower end).
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
So say for example a kicker cvx15 box is built towards the compact (smaller) size of the recommended specs tuning low like 32hz or high like 36hz make it peaky? Which way the lower or the highest? Sorry if i still cant quite understand.
Ive built over 6 boxes but usually i do the 15-16 but i just always wondered how the sound would be different if i went with say 12-14 of port.
Then build it. Build boxes with comparable volumes with lower port area per cube. Design, test, test, rebuild, and then test.
  • Who's Online   0 Members, 0 Anonymous, 1244 Guests (See full list)
