So I posted about two days ago that I have have power loss issues as to where my bass would drown out.
The replies that i got said to take out the capacitor , as for it being the problem.
well i took out the capacitor and hooked my two positives cords together so it would tie into my amp.
i turned on the truck and the bass hit for about 3 seconds and my amp completely turned off .
Now what is the problem?
ohhh and i checked voltage today. from the alternator to the battery im getting 14 volts. and from the battery to the capacitor i was getting 5 volts.
if that helps any
Edited by JohnayyBoyy
Something is screwed up with your wiring. The amp turned off because there was not enough voltage to keep it on.
What amp do you have? What gauge wiring do you have? How long is the wire? Have you done the big 3? And having 2 wires twisted together doesn't make the best electrical connection especially as wires get bigger and bigger - that might be your issue.
Edited by SnowDrifter
if that helps any
Check the connection of the wire running from the battery to the cap. Both AT the battery, and the AT the capacitor. Its probably got a loose wire and its not charging.
Edited by SoCaLBaMF
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
u are only getting 5 volts to from the battery to the cap? clean the terminals and replace the inline fuse
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Your wiring is hosed /thread
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you said you connected both ends of the positive wire together? (the one that used to go into the cap, and the one that went from the cap to the amp) thats a huge no-no dude. you have to replace the wire with a whole new run.
as far as the 9v worth of drop, it sounds like theres a loose connection somewhere. whether it be on the wire lugs attached to the wire, or a loose connection in the fuse block (only two i can think of at the moment). make sure you go over EVERY SINGLE contact point coming from the battery to the amp, down the whole line of wire.
you put both positives together to run to amp ? can we get pics of this wiring !?!?!
yeah ill try to get pics up tonight. i hooked the capacitor back up but ill post what wires i took off and hooked together.
