How do you go about using the DD-1 on a JL Audio HD series amp?
I could hook the DD-1 up to the speaker outputs and find the max undistorted voltage level, but putting that into different speakers with different impedances will cause massively different power levels. How do I use the DD-1 to find the max clean power I can give to eg a 3Ohm load?
Cheers
It only detects distortion in the amp so any clean signal in will be clean signal out regardless of the ohm load the amp is at.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
its the same thing. The bcp amps from RF do the same thing.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
