Skipping on USB... How do I fix?
At first I thought my amps were going into protect then I thought it was my line driver. After paying attention I realized I'm skipping my flash drive. How do I fix it? The head unit is mounted in solid. And it's skipping at half volume which is really concerning me.
Does it do it at low volumes too? It might be a bad rip
what headunit is it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
more info?
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Is it direct plug in to face? Try a extension cable.....x2 what deck... I have the alpine 9886 and with my old kenwood excelion no issues..now my bass just shakes the face so hard it turns volume down 2 clicks lol
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
If it's skipping with the music (hard beat or vibration) then it's probably the USB connector. Like Rick said, it's a problem on a lot of HUs.
If it's doing it through the song at whatever volume, then I'd suggest re-loading your drive... Move the entire contents to your computer, do a full format of the drive, then move it all back. I've had that issue while doing a lot of arranging of music on both my phone and my Sansa Fuse portable. You can also get a faster USB drive.
2007 Pacifica
  • Who's Online   1 Member, 0 Anonymous, 1558 Guests (See full list)
