I have one DC XL 18" powered by my RF T2500BDCP, it's been playing for a few months and is fully broken in
I will have a freshly reconed XL 18" with the next few weeks, I will be running the pair on the RF T2500bdcp @ 1 ohm, will I have any problems with one being new and one fully broken in?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Just run them both at lower volume until the other is broken in
Edited by battlewalrus
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
what i ve heard about sub break in is that f it let emm bump but idk never rlly put it to the test
If you read the post correctly, that is not the case.
you could play the fresh reconed one free air at a low freq, low volume for a little to lossen up the suspension
This is what I would reccomend. Or bump the new 18 in the same enclosure and rebuild once both have been broken in.
just dont go full tilt for a lil bit
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I didn't think about running the new one in my current enclosure, I may just do that
Good idea!
:drinks:
Id run the new one alone for a while... I tried the freeair trick and it takes time and doesn't work that great I think running it on music in the box is best...oh and id do 10 cubes net with 160sq of port tuned to 36... for 2 subs should slam... I've tried bigger in my hoe and didn't like it. I got those specs from a buddy that had 2 slamming in his hoe...
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
yea i will probably throw it in my current enclosure til its broken in and take my time building a nice new enclosure
i kinda feel like 10 cubes net is a lil small for 2500wRms for the pair, im thinking start with 12 cubes net and maybe make some removable parts to shrink the box and see what works better. im not interested in numbers this is a daily GP but i hope for atleast a 50 out of it
