I drew this diagram to help visualize the situation of how what is set up, wired, etc. when i connected the point shown in the picture, NOT EVEN TO THE SECOND BATTERY IN THE BACK YET, STARTED MAKING SPARKS (HOT ONE'S). I turn around and there is smoke under my hood, i hurry and disconnect it, go around the front of my truck and everything is fine except the 3 fuses up front are blown, none of the others.
WTF DID I DO WRONG?!?! i have done this multiple times with more amps and had no issues.
Edited by ChevyBoy95
If your having sparks, then you probably have a ground wire connected someplace to a positvie terminal.
Also, your missint 2 more fuses on the 2 runs of positive wires that run from front battery to rear batteries.
Your supposed to fuse those runs on each end, otherwise the 2 fuses under the hood are pretty much useless.
Did you have a remote in the amp and did it try to turn on? Could be an amp grounding itself (fried). Or the battery the amp is grounding to isnt grounded.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
you need to fuse the back batteries too for safety
you might have touched the wires by accident, there had to be a ground connected or it wouldnt have shorted like that
edit: because we have ninjas in this forum
Edited by Miguels
^ this. and good thing you had fuses. add 2 more to the other ends of those runs to the rear.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
ok, good to know. will do that.
i guess in the morning ill re check all my wires to make sure i wasn't mixing wires.
and for clarification, when you wire up multiple batteries like above, what order do you go in wiring? back batts to front, front to back? i know positive before grounds, but what order?
I personally go back to front. That way you have zero chance of harming your cars electrical since its in no way connected to your front engine bay. Hook it up, test the voltage, then connect to the front bank to the rear bank.
Edited by BassJunkie
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
went out and checked, the alt fuse is completely blown, and the 2 in the power runs didnt blow(1 looks almost new, the other is brownish black in the center but didnt melt through), but you cant tell they discolored just a bit.
i got out my DMM and checked all the lines that i touched to the short ground(front the other back battery with the mids highs amp on it) which caused the sparks. all read 0.00v except for the bass amp ground, which read 2.63v, i think that is just reserve charge in the amp, but if not someone explain.
  • Who's Online   1 Member, 0 Anonymous, 1382 Guests (See full list)
