ALPINE408 Posted January 17, 2012 Report Share Posted January 17, 2012 (edited) i thought you should allways hook up ground frist not power Edited January 17, 2012 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
Socky Posted January 17, 2012 Report Share Posted January 17, 2012 I thought the power them the ground but I like to triple check my stuff with the fuses out. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 17, 2012 Report Share Posted January 17, 2012 the only way you are going to get sparks is by completing the circuit. meaning you have a ground touching a power somwehre. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 17, 2012 Author Report Share Posted January 17, 2012 Why do you have a negative coming off alt? mechman recommends grounding the alt with a wire aside from the grounding it gets from the bracket, they even put an extra bolt to do it from. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ALPINE408 Posted January 17, 2012 Report Share Posted January 17, 2012 (edited) if you hook up ground frist then go to add power and it sparkes you take the power off no more sparks.. if you have power on frist and something grounds out guess what its a lot harder to stop.. if hooking up power frist if something grounds out when you already have a few powers hooked up how do you disconect fast? Edited January 17, 2012 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
Fosgatefeind Posted January 17, 2012 Report Share Posted January 17, 2012 is your front battery even grounded? Quote Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 17, 2012 Author Report Share Posted January 17, 2012 (edited) that's the thing, itdid it before even making contact with the battery those select grounds were going to. I didn't even have it in contact with the battery. (refer to the picture)it did it when the grounds touched when i was going to hook them up. Edited January 17, 2012 by ChevyBoy95 Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 17, 2012 Author Report Share Posted January 17, 2012 is your front battery even grounded? it has grounds, just forgot to put in the picture. they were not hooked up to the battery during the fireworks show. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted January 17, 2012 Author Report Share Posted January 17, 2012 Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
bre2ts Posted January 17, 2012 Report Share Posted January 17, 2012 if you hook up ground frist then go to add power and it sparkes you take the power off no more sparks.. if you have power on frist and something grounds out guess what its a lot harder to stop.. if hooking up power frist if something grounds out when you already have a few powers hooked up how do you disconect fast? You connect the positive first because it changes nothing by hooking up the ground first you have now given the battery a circuit and is now considered "hot". The reason why any battery would spark while connecting the ground is because somewhere in the circuit something is drawing power, whether it be the dome light because the doors open or the simple constants to clocks and radios. All of those things would cause the battery to spark a little at connection. Quote Feedback 1 | Feedback 2 you win some, you lose some Link to comment Share on other sites More sharing options...
