need to plug 4 18" sub cutouts. baffles are 4 layers thick. re-doing baffles is not an option. have a good idea of how to do it already, just wanted to get some more ideas before i actually jump into it. was thinking 2-3 cutouts that fit snug into the holes and one over top that would overlap the baffle on the front. cutouts would be glassed and bolted down from inside. outside layer would be rounded over on the edges glassed bolted down as well.
throw me some more ideas please?
Thanks.
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
switching to 2 of the new sa 8s per chamber. should be beaaasstttt. lol.
:No: need to switch to a smaller sub so the subs won't thermal after a minute of play lol. aren't moving enough to cool properly. going down to 15s, if anything i should gain a bit from testing in tom's jeep.
hiiiiiiii
16 12's 4th order
UBL - clicky
You could just get/make some 19" cutouts, the screw them into your existing speaker holes.
Edited by SnowDrifter
that's the plan for the outside layer. will have 2 additional layers that fit into the existing cutouts as well. outside will just be 1 layer thick. don't want it sticking out too much from the existing baffle.
hiiiiiiii
16 12's 4th order
UBL - clicky
if you go look at rustywca build in the astro van he had to do the same thing so you can see how he did it
ill go look into that. thanks
*edit - Just looked at it. his flush mount mine aren't flush mount. the plug was only 1 layer thick. ill need more than that because the 15s will be mounting to the plugs. maybe ill take the outside front layer down a bit so i can get flush.
and yes, 18s are going bye bye :( sucks that im losing so much cone but if the end result gets me louder then meh, doesn't matter lol.
Edited by irpirate
hiiiiiiii
16 12's 4th order
UBL - clicky
Id imagine youd have to make the plug and then glass it in place. and sand it all smooth. good luck better you than me.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
lol, yea...not lookin forward to it..
hiiiiiiii
16 12's 4th order
UBL - clicky
  • Who's Online   0 Members, 0 Anonymous, 766 Guests (See full list)
