If you've been running a multichannel amp for months with no noise, what would be the cause of noise appearing suddenly? What piece inside the amp is broken? And there is no noise from the sub. This is all theoretical.
SMD Super Seller
My Feedback Thread
my 1st guess would be the filters (caps). loss of the RCA ground would cause that too. obviously that could happen internally, not sure exactly how.
mine went away when i redid my big 3. it started wen a ground of my big 3 fell off n i ddnt notice.just fixed ground n lost noise.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
I literally just had this problem. I fixed it by running a ground from the batt to the amps. Although I only had my 2 channel amp for a day or so then the noise appeared, but the alt whine would only come if I ran full tilt then turned it down. And it didnt always make the noise then. It was weird but the ground was causing it in my situation.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
maybe bad rca's or they are close to the power wire?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
I have the same problem, check rcas
Edit: oops just relized you said you.changed them.
Maybe it'll just go away
Edited by BFF Larry
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Remember guys, no noise from the sub. Not a ground issue.
I had 0 noise from my sub man. The ground was on the frame and it had been my ground forever and I had ran other multichannel amps no problem. But for some odd reason it just came out of nowhere, and it did'nt affect my subs at all. idk just something to try if nothing else works imo.
Edit: and if you have some extra 0awg you could just try it without running it under the carpet or whatever, soo if it works it works, if it does'nt then o well just unhook it.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
