Cause of Alt Whine Out of Nowhere
OrionStang
Do you have an eq
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Make a Muting plug out of an old pair of rca's...cut them a few inches away from the plug and then solder the outer shield to the inner conductor for each. Insert said muting plug into the amp. If your noise disappears, it's not the amp....if it stays, well then it's the amp.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
Cut them, but not in half, right?
I'm gonna go swap the amps right now. See what happens.
Edited by OrionStang
SMD Super Seller
My Feedback Thread
Could try a portable music player and directly connect it to the RCAs on each amp.
If it's the headunit or the RCAs (probably not since you changed those) then the noise should go away with the portable player since its not connected to anything in the car.
Could also use a separate battery directly connected to the amp and disconnect your car power supply (batteries/alt).
If the noise stays with all these scenarios then something probably came loose in the amp.
Loose ground somewhere sounds possible.
Have a DMM? Could check the resistance between the amp ground terminal and the RCA grounds.
Should be directly connected (depending on the amp) and read ~0.3ohms... :shrug:
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
  • Who's Online   1 Member, 0 Anonymous, 1526 Guests (See full list)
