ALEX 323 Posted January 22, 2012 Report Posted January 22, 2012 i have a optima under the hood and i am getting two more for the back do i connect the two runs of wire to the front battery or to the alternator ? any knowledge shared would be appreciated thanks Quote aka KHRISS
C-Fizzy Posted January 22, 2012 Report Posted January 22, 2012 I would do one run of positive from the front batt to the back. One run of ground wire from the front batt to the back. And one run of positive from the alt to the back. Quote under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
BFF Larry Posted January 22, 2012 Report Posted January 22, 2012 (edited) Depending on stud size and room around the alternator, one run of 0 gauge should be good enough, could do two but its up to you. A run of 0 gauge from the alt to the + of the front battery. One run from the front battery positive to the back battery +. One run from the front battery -negative to the back battery -. Edit: ninjas are fast Edited January 22, 2012 by BFF Larry Quote Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
CaPRiCEx383 Posted January 22, 2012 Report Posted January 22, 2012 To the battery, Fuse each run within 18" of each battery. So 4 fuses on the 2 runs and you should be good, Better safe than sorry. Quote 90 Nissan 240sx Avic z-140bh Audison SR4 Audison Voce 6.5s CDT es-20 tweeters Sundown 1500v3 (2) DD 9510's 3 cube box 2 6" aeros XS Power D2400 & Xp950 Skyhigh/Knukonceptz/Rockford Fosgate wiring More Coming Soon.. Check my builds below. 97 Civic Hatch Build 86 Caprice Build you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
ALEX 323 Posted January 22, 2012 Author Report Posted January 22, 2012 can i ground the two back batteries to the chassis of the car if i have the big 3 ?? Quote aka KHRISS
C-Fizzy Posted January 22, 2012 Report Posted January 22, 2012 I always suggest doing a run of negative from front to rear. But if you can find a really good ground in the back. Then you're good. But on my car, I have a batt ground going to the engine block, then a ground run from front to back. Quote under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
matt402 Posted January 22, 2012 Report Posted January 22, 2012 can i ground the two back batteries to the chassis of the car if i have the big 3 ?? I always suggest doing a run of negative from front to rear. But if you can find a really good ground in the back. Then you're good. But on my car, I have a batt ground going to the engine block, then a ground run from front to back. id do both. Quote
Smoove Posted January 22, 2012 Report Posted January 22, 2012 Definitely fuse the runs. The voltage regulator on my 200amp Alt. ruined my Optima when it went out. My alt started pushing 18.6 volts to the battery. Yes an Optima can can blow bubbles. Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
ALEX 323 Posted January 22, 2012 Author Report Posted January 22, 2012 thats how i plan to do the big 3 0 gauge from ALT to front battery + then 0 gauge from the negative of the front battery to the engine block i i like the method larry said can one 0 gauge wire transfer enough juice to the two back batteries ? i was told not to ground two batteries in the same spot if i decide not to run the negative from front to back is it true? Quote aka KHRISS
BFF Larry Posted January 22, 2012 Report Posted January 22, 2012 TThe groundimg of your batts through a piece of 0 gauge wire, negative to negative, will only be good if you have upgraded the grounds underneath the hood. By doing the big 3 You can ground a batt in the same spot as another batt's ground. But you want to do the big 3 and up the groundage in your vehicle before adding those batts. Quote Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
