double baffle help
KenC210
Yes add the 0.75 to the external port section or the sheet volume will be deducted from your internal volume, also the extra 0.75 need to be added to the port lenght.
Personally I'd do the port down the middle, so you get free bracing. And you don't want 24" length for 35Hz tuning with 16^2 port area, 21" long is what you want, especially with end correction factored in...
With the shorter port you might be closer to 8cubes net which should be solid off the power you'll have.
care to explain this a little furthur?
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
