How many watts could I run
Im going to order a 250A alternator from singer and it will be running with a good battery up front and 1 maybe 2 batteries in the back. I was wondering how many watts I could run before I started to strain the electric system....I'm looking at wanting to run 2000-2500, nothing to insane but a decent amount.
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
wouldnt it depend on the effeincy of the amp?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Guys, this is simple math. We're all over the map here. I'll answer the question for 14.4 volts with Class D amplifiers, assuming:
- the alternator mentioned can indeed make its rated output at 14.4 Volts
- the vehicle requires 50 amps to run all stock accessories
- the batteries require between 7 and 10 amps each to maintain a surface charge
- the audio system is played at clipping (as loud as it'll play cleanly)
250 Amps - 50 Amps - 30 Amps (batteries, worse case scenario) = 170 Amps left for amplifiers
170 Amps x 14.4 Volts = 2,448 Watts
2,448 Watts x 75% Amplifier Efficiency = 1,836 Watts of amplifier power when reproducing sine waves
With music, even bass discs, duty cycle is about 50%
1,836 Watts / 50% duty cycle = 3,672 Watts of amplifier power when playing music
This number will indeed increase at 12.6 Volts (nominal voltage of the batteries) but too many variables are missing from the OPs question to make a SWAG (Scientific Wild Ass Guess).
Having said that, I have approximately 3,000 Watts RMS in my daily driver and a DC Power 250 Amp alternator with a single Red Top. And guess what . . . I can JUST pull voltage into the 12s with it all full tilt on Bass Mekanik.
This is indeed a case where the math simply doesn't lie.
Edited by snafu
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
2,448 Watts x 75% Amplifier Efficiency = 1,836 Watts of power to reproduce sine waves
I would listen to this guy. He just might know his stuff!
  • Who's Online   0 Members, 0 Anonymous, 1165 Guests (See full list)
