6 ohms(dvc's in parallel, subs in series), .6667 ohms (dvc's in parallel, subs in parallel), 2.667 ohms (dvc's in series, subs in parallel) 1.333 ohms (2 dvc's in series, 1 dvc in parallel, subs in parallel) .8889 ohms (2 dvc's parallel, 1 dvc in series, subs in parallel) 3 ohms (good for JL amps) ( dvc's in parallel, 2 subs in parallel, and then put them in series with the 3rd one)
Weird numbers come when you go in triple.
Edited by Omega5002
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Wow that is quite weird.. thanks!
E34 540iT/6
Your only options are really .67 and 2.67. 6 ohms too but that's kinda high. You wanna keep the voice coils wired together the same way on all 3 subs, otherwise they will get unequal amounts of power.
dont listen to ^^^^.
all in bold will cause issues.
Easier to read?
Easier to read?
Yeah, but still wrong
OP, go HERE for wiring options. Pick the number of subs and the coil configs and it will give you all your CORRECT options.
EDIT: Except under 1 ohm I guess :lol: just tried it to see.
Edited by Lbox88
Yeah, sorry about the mis-information on half of them, was trying to give every possibility on wiring option, which I did by hand, forgot not every wiring will work properly, though having an odd number of subs will bring odd numbers.
Thank you for pointing out my mistakes
2003 Kia Sorento
Team Subsonic Lows
