falcons03079313 Posted January 29, 2012 Report Posted January 29, 2012 Wheb you invert a subwoofer, do you lose some motor force because the motor is out of the box? Or does the power from the motor all gather at the cone? It just seems to me with the coil moving outside of the box you would lose some output.
KillaCam Posted January 29, 2012 Report Posted January 29, 2012 The only thing that really changes is the tuning of the box because you're taking the displacement out. Not much of a difference though. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
One Way Posted January 29, 2012 Report Posted January 29, 2012 When inverting subs you switch phase to reverse. T-line build- http://www.stevemead...e-t-line-build/
falcons03079313 Posted January 29, 2012 Author Report Posted January 29, 2012 When inverting subs you switch phase to reverse. That's what I was assuming that this was for. Makes a lot of sense now
HHR Ed Posted January 29, 2012 Report Posted January 29, 2012 NO change, and you do NOT have to switch phase. only if you are not switching all of your woofers. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
falcons03079313 Posted January 29, 2012 Author Report Posted January 29, 2012 I've messed with the phases on the head unit with a non inverted sub and they sound the same so Whatevs lol. Just didn't wanna miss anything
HHR Ed Posted January 29, 2012 Report Posted January 29, 2012 I've messed with the phases on the head unit with a non inverted sub and they sound the same so Whatevs lol. Just didn't wanna miss anything Thats different, that would change every amp and woofer on that output. What I mean is the "Phase" or polarity of a woofer dictates it's forward and backward movement. If all woofers in a system are wired equally with all positives to positive of the amps, and all negatives to negatives of the amps, they'd all move equal to eachother. Lets say they move out first, then back. Now, if you mount just one sub inverted, it's be moving the opposite direction of the other woofers, so you'd have to switch the polarity or "phase" of the wire to the woofer so that it moves the opposite way. That would make all woofers equal. As long as they move the same, you are OK, it doesnt matter if they all move out first or if they all move back first. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
MrSkippyJ Posted January 29, 2012 Report Posted January 29, 2012 what about the sub stage being out of phase with the rest of the system ed? what all does that affect? (or is it effect?) F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
falcons03079313 Posted January 29, 2012 Author Report Posted January 29, 2012 I've messed with the phases on the head unit with a non inverted sub and they sound the same so Whatevs lol. Just didn't wanna miss anything Thats different, that would change every amp and woofer on that output. What I mean is the "Phase" or polarity of a woofer dictates it's forward and backward movement. If all woofers in a system are wired equally with all positives to positive of the amps, and all negatives to negatives of the amps, they'd all move equal to eachother. Lets say they move out first, then back. Now, if you mount just one sub inverted, it's be moving the opposite direction of the other woofers, so you'd have to switch the polarity or "phase" of the wire to the woofer so that it moves the opposite way. That would make all woofers equal. As long as they move the same, you are OK, it doesnt matter if they all move out first or if they all move back first. When you put it that way I understand. So the phase doesn't matter if they are all facing the same direction
RooTxBeeR Posted January 29, 2012 Report Posted January 29, 2012 Phase doesn't matter as long as they are all playing in the same phase. My car is like that, I have one sub normal, another inverted. So for my inverted one I have the pos on sub to neg on amp, and neg on sub to pos on amp. My non inverted sub is wired up normally. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
