Omega5002 Posted February 8, 2012 Report Share Posted February 8, 2012 I found this Sabre Saw laying around in my garage, and I was wondering if it'll be strong enough to cut through 3/4 MDF ,when cutting circles for the sub, since I wanna start building my own box. My dad tells me it's only built to cut wood, but not mdf since it's tougher, but I wanna know opinions from you guys. If it's too weak, I'll just borrow a jig saw from one of my friends. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 8, 2012 Report Share Posted February 8, 2012 I bet it can. try it and find out. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Omega5002 Posted February 8, 2012 Author Report Share Posted February 8, 2012 Thanks for the reply Well, I don't wanna break it if it can't, which is why I'm asking, but I'll try, I have this old tiny box made of 5/8 mdf, so I'll test it on that. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
KillaCam Posted February 8, 2012 Report Share Posted February 8, 2012 The only thing you would break is the blade. But I doubt that will break unless you make tight curves. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
Omega5002 Posted February 8, 2012 Author Report Share Posted February 8, 2012 Well, I can probably use one if I find one or get a blade that would be appropriate for MDF, that's not a big problem. I'm just mostly worried about the Sabre Saw not having enough torque to cut through mdf, and having the motor overheat, though I think that sounds a bit exaggerated, but I don't know much about power tools, but I'm thinking that if it can cut through wood normally, it'll just take a slower time cutting through mdf but should be fine. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
djdew23 Posted April 13, 2012 Report Share Posted April 13, 2012 saw will work fine just hit lowes or homedepo and buy good blades i use .http://www.lowes.com/pd_1811-353-U19BO_0__?productId=3018414&Ntt=jigsaw+blade&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Djigsaw%2Bblade&facetInfo= blades work good and stay sharp.just remember to go slow and you will be fine Alpine IDA-X200 Car Digital Media Receiver AMP = power acoustik cpt1 2200d SUBS = 3 re audio 10" voodoo fuse and distribution blocks Voodoo Power Wire Voodoo RCA Leads Link to comment Share on other sites More sharing options...
Amart88 Posted April 13, 2012 Report Share Posted April 13, 2012 Your not going to hurt the saw. It just may take you a bit longer to cut. I have a black and decker cheap one and I use and abuse that thing with tight turns and never broke the blade. it just fell out once. My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
tacomaguy1 Posted April 13, 2012 Report Share Posted April 13, 2012 you found it in your garage...so if it did burn up you wouldn't be out any money Team Flex Issues Link to comment Share on other sites More sharing options...
doodcody Posted April 13, 2012 Report Share Posted April 13, 2012 i cut through two pieces of 3/4 mdf with one that was about that size.. blade gets hot but i was able to cut everything i needed it just takes longer.. for just one piece its fine Link to comment Share on other sites More sharing options...
