DC Sound Lab
I got it to push it. I did and found the limit. It was fun.
Tinted, you are an annoying little fuck.
I am far from little.
you guys keep taking your own advice, that's how companies make money on recones.
Are you related to Terrence and Phillip, them from Canada as well. Your farting here is a anoying smell.
A blown sub is a normal part of caraudio even more at SPL-burping.
"in the abundance of water, the fool is thirsty" Bob Marley
If you honestly think the HDC4 can't take 5,000 watts daily then, I guess I'm not going to change that. Because of course I wasn't feeding a pair of 3s almost 3,700 clamped each daily. Played with one HDC4, didn't like it, but it took the T4000 at .5 ohm nominal never clamped the setup so can't say. Have you played with the HDC4? Didn't think so.
Dont mean to spam the DC section with AQ, just figured I'd answer a question. :shrug:
Ok so it took 4k, now double that and see what happens.
There are very few subs that can take a true 5000w much less 7500w and how many of those are 12s? There is a reason that subs like the smd are not offered in a 12" version as a normal production item. But I'd bet if Steve asked ascendant to build him one just to play with, they probably would.
Orion,
If you want to try the level 6 1 more time, I would try the at cone if it wasn't built with it before and also I would have rusty send you the cone before he builds the recone and put a coat of resin on the back side of the cone.
Was playing 28, sounded great. Score was good
what was said score?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
43.x
This is where you know nothing. Companies don't make nearly what you think on recones. Most companies offer recones more as a service and not as a highly profitable part of the business.
This topic is now closed to further replies.
  • Who's Online   1 Member, 0 Anonymous, 4074 Guests (See full list)
