So as of the last 2 weeks my temp gauge seems to be fluctuating. It goes from the normal temperature to 1 line above where it usually rests.... I checked the coolant level after the car cooled off and it seems to be at normal level...
Anyone have any idea what else could cause the temperature to go up and down?
Team MaxRetribution
Si Vis Pacem Parabellum
It could be your Temperature Sensor
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Weather has been up and down....Also the temp issue started after I had to drive down to FL and Back round trip it was like 33hrs in the car....On the way home I noticed it was 1 click higher and ever since its been bouncing
Team MaxRetribution
Trip may have caused stressed the Impala didn't want to take either that or your temp gauge is f'd up like mario said. Trips that long are no good on any car, did you have it serviced prior to the trip?
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Your thermostat could be sticking...just an idea. LT.Smoke check out naioa.com , it's strictly an Impala forum me and a couple people on here are members of and you can get a lot of help regarding this issue you're having..
Not advertising for another forum, just tryna help another basshead out!
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
it's more likely the thermostat than the temp gauge. like billy said.
Mine used to go a bit above normal than finally open and go back down to normal.
good news is it's only a couple dollar fix.
Eclipse cd7000
thermostat. replace it with an oem gm t-stat, should do it. along with bleeding the coolant system
  • Who's Online   0 Members, 0 Anonymous, 576 Guests (See full list)
