Ok, So I had my subs wired to a low power 4 channel amp, to two channels, and a pair of 6x9's to the other 2 channels. Well I looked up my amp today, it does 40W x4 @ 4 ohm, 100W x2 @ 4 ohms, and 50W x4 @ 2 ohm. Well I had my subs wired down to 2 ohms, then bridged them to see what the difference I would get would be. Although my amp isn't that stable like that, it played for a bit till I blew my fuse. My question is, When I had it playing at 50W a sub, then moved to 50W x2 Bridged, the lows got realllly loud, Louder than ever. But the higher bass when it would hit would start to make the surround wrinkle, I couldnt even turn my SW LVL up at all when a high not was playing without risking some over excursion. Is their something wrong with my box as to why it does it? I am scared now to actually put RMS power to these subs in the fear that they wont be able to play. FYI theya re 260RMS.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Bump, still wondering about putting RMS power to them.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Never said it was clipping... Or anything of the like. I said when I doubled my power, my subs move A LOT more and wrinkle the surround when I barely play it loud, I can't even turn the volume to full or use the SW LVL with high base or I will reach the xmax of the subs. Not to be a dick but it helps to read.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Run your amp at the rated impedance. Not half
And how are you reaching xmech putting less than half power do them? What size subs do you have and what are your box specs?
Edited by SnowDrifter
I do run my amp at rated, was just testing something out. And that's whats confusing me, I am barely reaching half their RMS off the amp like that and I am reaching the XMAX almost. I have 2 JBL GT1000d 10" subs, on a Alpine MRV-F250, I forgot a lot about the box but I believe I built it for 2cu internal. I did screw up on the port, so the L port has 2 different widths. The end of the port that touchs the outside is 2.75" wide and the bottom part of the port you cant see inside of the box is 2.25: wide
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Mine is on you over driving your amp causing distortion. That's why you blew a fuse
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You asked about putting rms to a sub, I gave an answer on why a sub might not take rms...never said you were clipping.
Not to be a dick but you need to read better it looks like...
Edited by sprkn_ranger
I could understand that one, Also I am going to throw this out their. Before when I had them bridged to 4 ohms, They would also do this but after I turned the SW LVL up to about halfway, high notes would do the same thing. Sometimes I would actually hear the sub hit its limit and hear the VC smacking the bottom of the magnet
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
how do you know you're not clipping? its impossible for you to just be like "i know" without saying how you tuned the gains
  • Who's Online   0 Members, 0 Anonymous, 1005 Guests (See full list)
