i was setting the gain on an audiopipe ap30001d with the 40hz 0 db tone and i set everything up the way it was supposed to be. i had the dd-1 negative connected to the amps ground and i noticed while turning up the gain that it would distort with the gain very low, but not at minimum. so i set the gain down to the point with no distortion. then while the dd-1 was still on i disconnected the dd-1 negative and connected it to the negative output terminal on the amp and it sparked a little bit when it touched the negative on the amp output terminal and the distortion light instantly lit up. i tried seting the gain all the way down to minimum and it still shows distortion. what happened? before i did that even with the gain at minimum there was no distortion.
Posted (edited)
Turn down the volume on your source
Edit: And why would you connect to the negative on the amp? You may have fried it
Edited by SnowDrifter
use -10 db on your bass amp......or -5 but not 0.
Follow my Tweet (Twitter)
why not? the negative on the amp is fine. It should be the same as any other "negative" on the car.
Posted (edited)
the volume a the source is at max undistorted volume. i dont know i just decided to try it.
the gain knob dont always have to be all the way up as a matter of fact its even better when its turn down, makes the amp work less
Edited by Miguels
Posted (edited)
go back and set it with the -5 or -10 tones like steve said and report back. No the dd1 did not mess it up, i thought the same thing with my system BUT the dd1 can in no way harm your system, i was just being a dumbass.
Edited by Tebo
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Maybe you should look at the fact that the audiopipe amps arent exactly known for their clean power............
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
